Author Topic: Stereotype min width doesn't work  (Read 4667 times)
Guillaume
    • www.umlchannel.com
« on: August 07, 2019, 07:57:58 pm »
I created a UML profile with stereotyped UML components. To cater for the length of the stereotype, I set a min width via the SizeX stereotype property e.g. 200.
In the XML file, I get the cx="200" as expected.
This UML profile is delivered via an MDG. When I create the stereotyped components, the width remains the default one.
Any idea?
Guillaume
Re: Stereotype min width doesn't work
« Reply #1 on: August 07, 2019, 08:18:25 pm »
Try a shape script with preferredWidth.
David Rains (bioform)
« Reply #2 on: August 08, 2019, 12:33:33 am »
I have a similar issue, I am chasing on modifying the default "frame" size of the source element for the stereotyped image created with a shapescript...
Okay, got that working (redrew image to occupy 100X100 in X/Y in shapescript and adjusted shape proportions accordingly) then added...
   fixedAspectRatio = "true";    defsize(100,100);
When loaded via MDG, dragged onto diagram Frame Same size as Image... then used corner to shrink as needed.... changed the font, etc. since it is a package that I stereotype, once I adjusted it... I can't just copy and paste.... have to repeat those steps each time :( Could add some automation code later....
« Last Edit: August 08, 2019, 02:37:36 am by David Rains »
Guillaume
« Reply #3 on: August 09, 2019, 04:15:28 pm »
Thanks for your reply. I tried with the Shapescript but the UML component width is still the same. I'll you know if I find a solution once I've investigated further.
Guillaume
Guillaume
« Reply #4 on: September 18, 2020, 08:05:03 pm »
Reopening this thread, I found that it works when you set both the X and Y e.g. x = 110, y = 60.
Guillaume
