Author Topic: Use case and sequence diagram using tables  (Read 4520 times)
ignaciogrande
« on: August 08, 2019, 05:29:39 pm »
Hello forum, first post here!
Two months ago I had a crash-course of EA14 and now I'm trying to use it to write a design document.
I need to document some use cases with sequence diagrams and in the course I saw a way to do it, creating a Use Case and then right-clicking on it, Add, Interaction, With Sequence diagrams.
Then if I remember correctly, there are two ways to do it, one is directly adding elements to the diagram but there was a newer, nicer way to do it with a table, where you can add the interactions there and the sequence diagram was filled automatically. It seemed a better way to do amendments or creating alternative paths. I think you could create an alternative path from a step and then join it to the main path, and so on.
However, I can't find now how to view and add this step table. I have added the use case using the wizard and it looks like the one in the course, but how can I get the table where I can write down the steps?
Thank you.
Re: Use case and sequence diagram using tables
« Reply #1 on: August 08, 2019, 05:44:37 pm »
Not sure, but open the use case properties and click the Scenarios to the left which allows to edit the scenario steps.
ignaciogrande
« Reply #2 on: August 08, 2019, 06:48:15 pm »
Yes, that is! Thanks, I could not find that window. From there I managed to make simple activity and interaction diagrams writing down the steps and defining the actors/modules. Not the most intuitive way but I think it's better to make modifications later.
Regards
jfzouain
« Reply #3 on: August 09, 2019, 12:56:05 am »
Hi Ignacio
If you really want to create design document, you my book available in simple steps.
UML ERP Workshop - Writing a BRD with Enterprise Architect - Full BRD
https://leanpub.com/uml-erpworkshop
Best regards
Jose Zouain
