Author Topic: MDG stylesheets cannot be used by linked documents  (Read 3969 times)
« on: August 08, 2019, 06:35:14 pm »
If I create a stylesheet in the resources I can use that in both my linked documents and in in report generation.
But when I include this stylesheet in an MDG, and import that MDG in a new model, only the report generation can use this stylesheet. It cannot be used in the linked documents.
This is pretty annoying as I combine linked documents in document generation, and that only works fine it they both use the same stylesheet.
Steps to reproduce:
- add a stylesheet to an MDG
- import this MDG into a model
- open a linked document
- try to apply this stylesheet in the linked document
currently this only workaround is to import the stylesheet with import reference data (making is no longer read-only like the MDG stylesheet)
Re: MDG stylesheets cannot be used by linked documents
« Reply #1 on: August 13, 2019, 08:56:59 am »
I hope you've reported this, because its a :thumbsup: from me :+1:
« Reply #2 on: August 13, 2019, 02:43:43 pm »
I did, and they confirmed it was a bug they will fix someday.
