Author Topic: Export Databases and tables to CSV  (Read 4372 times)
Typia
« on: August 08, 2019, 06:45:50 pm »
Hi guys,
I would like to know if there is any way to export a database to a csv file giving tables fields and related attributes like field type, field length ..
Many thanks
Re: Export Databases and tables to CSV
« Reply #1 on: August 08, 2019, 07:40:23 pm »
Not that easy.
You would need to write an SQL query to get the info out, and not all of the info is that simple to find.
Here a snippet of VBScript code with the query that I use to get the data out. It gets more then only the tables and columns, it also get our logical data model and the mapping between LDM and TDM (Technical Data Model => Database)
If you use the query alone you can put it into an SQL search and from the search results export to CSV.
Or you can write a script and export it directly to Excel like I did
function getMappingDetails(sourcePackage, targetPackage)
'get the pakage tree id's
dim sourcePackageTreeIDs
sourcePackageTreeIDs = getPackageTreeIDString(sourcePackage)
dim targetPackageTreeIDs
targetPackageTreeIDs = getPackageTreeIDString(targetPackage)
dim sqlGetMappingDetails
sqlGetMappingDetails =  "select        " & vbNewLine & _
"   ldm.[Domain], ldm.Entity as [Class], ldm.Attribute as Attribute, ldm.AttributeType as AttributeType                                                             " & vbNewLine & _
" , ldm.TimeSliced, ldm.Versioned, ldm.Mandatory, LEFT(ldm.facets,LEN(ldm.facets)-PATINDEX('%[^'+CHAR(13)+CHAR(10)+']%',REVERSE(ldm.facets))+1) as Facets           " & vbNewLine & _
" , ldm.Type as LDMType, ldm.CLASSGUID as [Guid]        " & vbNewLine & _
" , tdm.[Database], tdm.Entity as [Table], tdm.Attribute as [Column]        " & vbNewLine & _
" , tdm.Datatype, tdm.PK, tdm.NotNull        " & vbNewLine & _
" , case when left(convert( varchar(max),tdm.[Default]), 1) = '''' then '''' else '' end + convert(varchar(max),tdm.[Default]) as [Default]                         " & vbNewLine & _
" , tdm.Type as TDMType, tdm.CLASSGUID as [Guid]        " & vbNewLine & _
" , case when p.Package_ID is null then 'false' else 'true' END as EmptyMapping        " & vbNewLine & _
" , tdm.Comment, tdm.MappingNotes        " & vbNewLine & _
" from (        " & vbNewLine & _
" select o.ea_guid AS CLASSGUID, o.Object_Type AS CLASSTYPE, o.name as Entity, null as Attribute, 'Table' as Type, tv.Value as LDMGuid, p1.Name as [Database]       " & vbNewLine & _
" , CASE WHEN CHARINDEX('<description>',tv.NOTES) > 0 THEN        " & vbNewLine & _
"   SUBSTRING(tv.NOTES,CHARINDEX('<description>',tv.NOTES)+LEN('<description>'),        " & vbNewLine & _
"              CHARINDEX('</description>',tv.NOTES)-CHARINDEX('<description>',tv.NOTES) - LEN('<description>')) END as Comment                                      " & vbNewLine & _
", null as Datatype, null as PK, null as NotNull, null as [Default] , tv.Notes as MappingNotes        " & vbNewLine & _
" from t_object o        " & vbNewLine & _
" left join t_objectproperties tv on tv.Object_ID = o.Object_ID        " & vbNewLine & _
"                                                       and tv.Property in ('sourceElement','linkedAssociation', 'linkedAttribute')                                 " & vbNewLine & _
" inner join t_package p on p.Package_ID = o.Package_ID        " & vbNewLine & _
" left join t_package p1 on p1.Package_ID = p.Parent_ID        " & vbNewLine & _
" where 1 = 1        " & vbNewLine & _
" and o.Object_Type = 'Class'        " & vbNewLine & _
" and o.Stereotype = 'table'        " & vbNewLine & _
" and o.Package_ID in (" & sourcePackageTreeIDs  & ")        " & vbNewLine & _
" union all        " & vbNewLine & _
" select a.ea_guid AS CLASSGUID, 'Attribute' AS CLASSTYPE, o.name as Owner, a.Name as Attribute, 'Column' as Type, tv.VALUE as LDMGuid, p1.Name as [Database]       " & vbNewLine & _
", a.type  + CASE WHEN dt.Size = 1 THEN '(' + cast(a.Length as varchar) + ')'        " & vbNewLine & _
"WHEN dt.Size = 2 THEN '(' + cast(a.Precision as varchar) + ', ' + cast(a.Scale as varchar)  + ')'        " & vbNewLine & _
" ELSE '' END as Datatype        " & vbNewLine & _
",a.IsOrdered as PK, a.AllowDuplicates as NotNull, a.[Default]  , tv.Notes as MappingNotes        " & vbNewLine & _
" from t_attribute a        " & vbNewLine & _
" inner join t_object o on o.Object_ID = a.Object_ID        " & vbNewLine & _
"left join t_datatypes dt on dt.ProductName = o.GenType        " & vbNewLine & _
"                                         and dt.DataType = a.Type        " & vbNewLine & _
"                                         and dt.Type = 'DDL'        " & vbNewLine & _
" left join t_attributetag tv on tv.ElementID = a.ID        " & vbNewLine & _
" )tdm        " & vbNewLine & _
" full outer join (        " & vbNewLine & _
" select  o.ea_guid AS CLASSGUID, o.Object_Type AS CLASSTYPE, o.name as Entity, null as Attribute, o.Object_Type as Type, o.ea_guid as LDMGuid, p1.Name as [Domain] " & vbNewLine & _
" , tc.Value as TimeSliced, vs.Value as Versioned        " & vbNewLine & _
" ,null as Mandatory, null as AttributeType, null as facets        " & vbNewLine & _
" left join t_objectProperties tc on tc.Object_ID = o.Object_ID        " & vbNewLine & _
" and tc.Property = 'Timesliced'        " & vbNewLine & _
" left join t_objectProperties vs on vs.Object_ID = o.Object_ID        " & vbNewLine & _
" and vs.Property = 'Versioned'        " & vbNewLine & _
" and o.Package_ID in (" & targetPackageTreeIDs  & ")        " & vbNewLine & _
" select a.ea_guid AS CLASSGUID, 'Attribute' AS CLASSTYPE, o.name as Owner, a.Name as Attribute, 'Attribute' as Type, a.ea_guid as LDMGuid, p1.Name as [Domain]     " & vbNewLine & _
" , a.lowerbound as Mandatory, isnull(cl.Name, a.Type) as AttributeType        " & vbNewLine & _
",  case when ftd.Property is not null then ftd.Property + ':' + ftd.Value + char(13) + char(10) else '' end                                                        " & vbNewLine & _
"+ case when ffd.Property is not null then ffd.Property + ':' + ffd.Value + char(13) + char(10) else '' end                                                         " & vbNewLine & _
"+ case when fl.Property is not null then fl.Property + ':' + fl.Value + char(13) + char(10) else '' end                                                            " & vbNewLine & _
"+ case when fmie.Property is not null then fmie.Property + ':' + fmie.Value + char(13) + char(10) else '' end                                                      " & vbNewLine & _
"+ case when fme.Property is not null then fme.Property + ':' + fme.Value + char(13) + char(10) else '' end                                                         " & vbNewLine & _
"+ case when fmi.Property is not null then fmii.Property + ':' + fmii.Value + char(13) + char(10) else '' end                                                       " & vbNewLine & _
"+ case when fmi.Property is not null then fmi.Property + ':' + fmi.Value + char(13) + char(10) else '' end                                                         " & vbNewLine & _
"+ case when fmil.Property is not null then fmil.Property + ':' + fmil.Value + char(13) + char(10) else '' end                                                      " & vbNewLine & _
"+ case when fml.Property is not null then fml.Property + ':' + fml.Value + char(13) + char(10) else '' end                                                         " & vbNewLine & _
"+ case when fp.Property is not null then fp.Property + ':' + fp.Value + char(13) + char(10) else '' end                                                            " & vbNewLine & _
"as facets        " & vbNewLine & _
(part 1 of the code)
« Reply #2 on: August 08, 2019, 07:41:17 pm »
part 2 of the code (stupid 20000 character limi :-X)
& _
"  left join t_attributetag tc on tc.ElementID = a.ID        " & vbNewLine & _
" left join t_attributetag vs on vs.ElementID = a.ID        " & vbNewLine & _
" left join t_object cl on cl.Object_ID = a.Classifier        " & vbNewLine & _
" left join t_objectproperties ftd on ftd.Object_ID = cl.Object_ID        " & vbNewLine & _
" and ftd.Property = 'totalDigits'        " & vbNewLine & _
"left join t_objectproperties ffd on ffd.Object_ID = cl.Object_ID        " & vbNewLine & _
" and ffd.Property = 'fractionDigits'        " & vbNewLine & _
"left join t_objectproperties fl on fl.Object_ID = cl.Object_ID        " & vbNewLine & _
" and fl.Property = 'length'        " & vbNewLine & _
"left join t_objectproperties fmie on fmie.Object_ID = cl.Object_ID        " & vbNewLine & _
" and fmie.Property = 'minExclusive'        " & vbNewLine & _
"left join t_objectproperties fme on fme.Object_ID = cl.Object_ID        " & vbNewLine & _
" and fme.Property = 'maxExclusive'        " & vbNewLine & _
"left join t_objectproperties fmii on fmii.Object_ID = cl.Object_ID        " & vbNewLine & _
" and fmii.Property = 'minInclusive'        " & vbNewLine & _
"left join t_objectproperties fmi on fmi.Object_ID = cl.Object_ID        " & vbNewLine & _
" and fmi.Property = 'maxInclusive'        " & vbNewLine & _
"left join t_objectproperties fmil on fmil.Object_ID = cl.Object_ID        " & vbNewLine & _
" and fmil.Property = 'minLength'        " & vbNewLine & _
"left join t_objectproperties fml on fml.Object_ID = cl.Object_ID        " & vbNewLine & _
" and fml.Property = 'maxLength'        " & vbNewLine & _
"left join t_objectproperties fp on fp.Object_ID = cl.Object_ID        " & vbNewLine & _
" and fp.Property = 'pattern'        " & vbNewLine & _
" )ldm on ldm.LDMGuid = tdm.LDMGuid        " & vbNewLine & _
" left join t_package p on p.ea_guid = tdm.LDMGuid        " & vbNewLine & _
" order by isnull(ldm.Entity, 'ZZ'), ldm.Attribute, tdm.Entity, tdm.Attribute        "
    dim queryResults
'debug
' Dim debugFile
' set debugFile = new TextFile
' debugFile.Contents = sqlGetMappingDetails
' debugFile.FullPath = "h:\temp\mappingQuery.txt"
' debugFile.Save
set queryResults = getArrayListFromQuery(sqlGetMappingDetails)
'return
set getMappingDetails = queryResults
end function
« Reply #3 on: August 08, 2019, 08:07:04 pm »
Stupid indeed. However, you could have saved 10k chars in spaces xD
« Reply #4 on: August 08, 2019, 08:56:25 pm »
Sure, but I just wanted to copy the code from the source as it, without messing with the formatting.
(in EA's script editor it looks a lot better)
