Author Topic: v15 – Copying and Pasting from Search into diagram ALWAYS brings up the dialog  (Read 3434 times)
I have the [ x ] Only Show if Ctrl pressed on the Paste dialog, so for drag and drop, it doesn't appear.
However, if I select an item on (say) the Model Search list of returned items and Copy [Ctrl+C] when I paste to the diagram because I use [Ctrl+V], the dialog always (irritatingly) shows.
I note that Paste on the context menu shows as [Shift+Insert], however, [Ctrl+V] is SO ingrained, that the dialog setting should ONLY apply to drag and drop.
Reported,
[Edit: more irritatingly, if you select multiple items, pasting with [Ctrl+V] does NOT bring up the dialog.]
« Last Edit: August 23, 2019, 10:33:13 am by Paolo F Cantoni »
