Author Topic: V15: EA crashes when trying to open SQL model with security  (Read 6392 times)
« on: August 23, 2019, 06:01:14 pm »
We are trying to move to version 15.0.1508 (from 12.1.1230) and after we transferred the .eap model to the SQL server the application crashes when we try to connect.
I tried it with version 12.1.1230 and with that version I'm still able to connect.
If I disable the security we can connect with v15 again.
I tried adding my AD user to enable windows authentication login and re-enabled security, but that made it crash again.
This problem does not happen when we try to open the .eap file from which the model was transferred.
I disabled all the add-ins but that didn't make a difference either.
Reported
Re: V15: EA crashes when trying to open SQL model with security
« Reply #1 on: August 23, 2019, 06:01:41 pm »
I think I narrowed it down to the windows authentication checkbox.
If I disable the windows authentication checkbox on my SQL server model I can open it again with v15
If I disable and enable windows authentication on the .eap model it also crashes in v15.
All of the models still open just fine with version 12.1
« Reply #2 on: August 23, 2019, 06:09:58 pm »
Did another test.
- Open the EAExample model (.eap or SQL server both react the same)
- Enable security
- Login as another user (admin-password)
- Go to Configure | Users
- Check Accept Windows Authentication checkbox
- Close model
- Open the same model -> EA crashes.
« Reply #3 on: August 30, 2019, 09:20:48 pm »
Problem is fixed in the version 15.0.1509 that was released today.
Excellent work from Sparx! :)
