Author Topic: Automated script for draw EA.Element (Activity) into EA.Diagram  (Read 4274 times)
cathello
Hi all,
I builded an automated script that able to read from database, create objects into Diagram and create relationship between them.
I have a little problem. When create a new relationship througth a Connector i need to create with style "Orthogonal - Rounded" (default is Custom)
Is it possible?
I read that can i able to change the default routing style through the preferences but the type Routed is different to Orthogonal - Rounded.
This is my script to create a Connector:
var connectorDependency as EA.Connector;
connectorDependency = elementSource.Connectors.AddNew("", "Realization");
connectorDependency.Stereotype = "DataAssociation";
connectorDependency.Type = "Dependency";
connectorDependency.SupplierID = elementDestination.ElementID;
connectorDependency.Update();
currentDiagram.Update();"
Thanks for help.
Catello.
cathello
Re: Automated script for draw EA.Element (Activity) into EA.Diagram
« Reply #2 on: August 28, 2019, 08:01:36 pm »
Thanks a lot.
Just a last question. What is the method in JScript that overwrite the style? I tried this:
                        for (var j=0; j < currentDiagram.DiagramLinks.Count; j++)
            var link as EA.Diagram.DiagramLinks;
            link = currentDiagram.DiagramLinks.GetAt(j);
            link.WriteStyle = "Mode=3;TREE=OR;";
« Reply #3 on: August 28, 2019, 08:48:04 pm »
I'm not sure (I don't use Jscript), but I suppose it's just
link.Style = "Mode=3;TREE=OR;";
Don't forget to save your changes by calling update()
cathello
« Reply #4 on: August 28, 2019, 08:57:55 pm »
:) I found.
I used the class EA.Diagram.Diagram Links that has not the Style parameter but StyleEx. I tried to use an object EA.Diagram Links and now work it!!!
Thank you so much :)
