Author Topic: v15 – Drop Diagram doesn’t list the diagram name on the dialog when multiple  (Read 6380 times)
When you drag multiple diagrams onto another diagram, the Dialog pops up asking you what type of an instance you want to create.  The Dialog DOESN'T tell you which diagram you are dealing with.  The instances are NOT created until the set is completed - so you can't tell which diagram you are dealing with.  This needs to be rectified.
Reported,
Has been wrong that way ever since. Sparx' likely answer: drop one after the other if unsure.
