Author Topic: How do I set just the stereotype of an element in scripting?  (Read 7116 times)
mse
« on: August 31, 2019, 03:02:18 am »
I'm trying to make a selection of elements and set the stereotype field of those elements using scripting. I started off with the MultiSelectionExample script. I thought I could add just this one line:
set theElement.Stereotype = "requirement"
That gives me an error stating that an object is required.
How can I set the stereotype of multiple elements in a package?
Here is the source code:
option explicit
!INC Local Scripts.EAConstants-VBScript
' Outputs the details of elements selected in the Project Browser
' Related APIs
' Repository API - http://www.sparxsystems.com/enterprise_architect_user_guide/12.1/automation_and_scripting/repository3.html
sub MultiSelectionExample()
' Show the script output window
Repository.EnsureOutputVisible "Script"
Session.Output( "VBScript Project Browser Multi Selection Example" )
Session.Output( "=======================================" )
' Get the set of selected items as a collection
dim selectedElements as EA.Collection
set selectedElements = Repository.GetTreeSelectedElements()
dim selectedElementCount, i
selectedElementCount = selectedElements.Count
if selectedElementCount > 0 then
' Iterate over all of the selected elements
for i = 0 to selectedElementCount - 1
dim theElement as EA.Element
set theElement = selectedElements.GetAt( i )
' Output the details of the current selected element
dim message
message = "Element Name: " & theElement.Name
message = message & vbCrLf & "GUID: " & theElement.ElementGUID
message = message & vbCrLf & "Type: " & theElement.Type
message = message & vbCrLf & "Stereotype: " & theElement.StereotypeEx
message = message & vbCrLf & "ID: " & theElement.ElementID
message = message & vbCrLf & vbCrLf
Session.Output( message )
next
Session.Output( "Done!" )
else
' No item selected in the tree, or the item selected was not an element
Session.Prompt "This script requires one or more elements to be selected in the Project Browser." & _
vbCrLf & "Please select a range of elements in the Project Browser and try again.", promptOK
end if
end sub
Re: How do I set just the stereotype of an element in scripting?
« Reply #1 on: August 31, 2019, 04:44:02 am »
Use StereotypeEx instead of Stereotype.
« Reply #2 on: August 31, 2019, 03:02:15 pm »
You may only use the "set" keyword when setting objects.
set myObjectVariable = someObjectPrimitive types like string or integer you should just use
myPrimitiveVariable = somePrimitiveValue
mse
« Reply #3 on: September 02, 2019, 05:05:31 pm »
I made a small change based on everyone's comments:
theElement.StereotypeEx = "requirement"
That has no affect however when running the script. Clearly the script is going through each selected element in the project browswer, but the stereotype does not change.
« Reply #4 on: September 02, 2019, 05:14:04 pm »
You never update anything in your script.
mse
« Reply #5 on: September 02, 2019, 05:21:32 pm »
Apparently I have the wrong idea of how to update. I thought a simple assignment would do the trick. How do I update the stereotype then?
« Reply #6 on: September 02, 2019, 05:34:17 pm »
After changing stuff on an API object you have to call Update() to save those changes to the database.
mse
« Reply #7 on: September 02, 2019, 05:44:49 pm »
That worked perfectly. All requirements are now converted to SysML requirements. Thanks!  :)
One more follow-up question. I would like to transfer some text from two tagged values to the standard SysML .id and .text fields. However, just writing
theElement.id = ...
theElement.text = ...
is not enough, the fields are not recognized even though they are part of the SysML requirement element. How can I update these fields?
« Reply #8 on: September 02, 2019, 06:06:12 pm »
I guess these are stored as tagged values (or is text stored in the notes field)
If tagged values then you'll have to loop the tagged values and find the one with name ID.
You can then set it's value and save it (by calling update())
mse
« Reply #9 on: September 02, 2019, 09:38:04 pm »
Looping through tagged values and identifying by name did the job just fine. And of course do not forget to Update(). Thanks again for your help!  :)
