Author Topic: Where is 'set as icon' option in EA 15 for Image assets?  (Read 6872 times)
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« on: September 01, 2019, 02:17:05 am »
As seen in https://community.sparxsystems.com/tutorials/1280-prolaborate-architecture-using-ea15-image-assets I was loooking for the option "set as icon' when drag&drop an image asset over a class in a diagram but some of the options shown are not present. Where are they?
Takeshi K
    • Sparx Systems Japan
Re: Where is 'set as icon' option in EA 15 for Image assets?
« Reply #1 on: September 02, 2019, 03:52:45 pm »
Hello Arquesoft,
To use the option, the target object must be Custom Style.
Right-click the target object in a diagram and select 'Appearance' | 'Enable Custom Draw Style', and then try again.
t-kouno
« Reply #2 on: September 09, 2019, 06:20:35 am »
Hello Arquesoft,
Thanks! I also discovered that you can create the diagram as SimpleDiagram in order all elements have the custom style enabled.
