Author Topic: [V13-14-15]Publishing any MDG Technology to model results in import errors.  (Read 12794 times)
viktorb
This issue is getting quite ridiculous as you will see below:
My team has created a brand new MDG technology and now we'd like to publish it to our PostgreSQL based EA project.
We want to publish to MDG directly on the model so people don't have to install the technology first.
However whenever we import an mdg technology we receive the following error:
Elev8SIM being our new MDG technology.
I've created a brand new ea project (without a DB) and imported MDG there and it worked just fine.
suspecting something was wrong with our database I monitored the queries only to find out there wasn't anything wrong.
I created a brand new EA project this time with a PostgreSQL database and I receive the same errors, again no issue in the database logs.
To make it more bizarre this issue only happens to some people in our team. The MDG's loads just fine for 2/4 people in our team.
I've also tried changing EA versions from 13 to 14 and from 14 to 15, they all give me the same result.
If you require more information I'm happy to provide it as this issue frustrates me to no end.
Any on guidance on how to resolve this is very appreciated.
datasource options:
Re: [V13-14-15]Publishing any MDG Technology to model results in import errors.
« Reply #1 on: September 02, 2019, 10:13:32 pm »
Some of you might have path setup to load MDG's from, which might conflict with any MDG's loaded in the model.
From the Manage MDG's dialog there a button (advanced) that allows you to specify a path.
viktorb
« Reply #2 on: September 02, 2019, 10:38:38 pm »
Thank you for your comment.
The list is both empty for me and my colleagues where the MDG works.
We've also confirmed that the MDG technology works for Web EA.
