Author Topic: Get the list of tags of a connector  (Read 6219 times)
tzafrir
« on: September 13, 2019, 06:07:01 am »
I am trying to get the list of tags that are associated with a ST, that is associated to a connector.
I found an API that gets the tag from the connector:
EA.Collection tagCollection = connector.TaggedValues;
but trying to run over them with simple loop:
for(short i = 0;i< tagCollection.Count; i++)
  EA.TaggedValue tag = (EA.TaggedValue)tagCollection.GetAt(i);
  tagName = tag.Name;
I get exception that casting cannot be done, and can not do this conversion.
Can someone tell me how can I overcome it? or other way to get the tags of the connector?
Re: Get the list of tags of a connector
« Reply #1 on: September 13, 2019, 06:08:40 am »
Not sure about that Java stuff, but try a long instead of the short. Pretty sure the tagCollection.Count returns a long that can't be casted to short.
« Reply #2 on: September 13, 2019, 06:11:48 am »
try casting to EA.ConnectorTag
It helps to read the manual you know: https://sparxsystems.com/enterprise_architect_user_guide/15.0/automation/connector.html
« Reply #3 on: September 13, 2019, 08:46:05 am »
This would be the problem.
I believe short is correct and Java will complain if you pass GetAt a long or int.
« Reply #4 on: September 13, 2019, 09:20:30 am »
So as we are at guessing: what I do in such cases is to comment things stepwise to find the culprit.
tzafrir
« Reply #5 on: September 15, 2019, 03:43:34 pm »
Thanks for the help,
casting to EA.ConnectorTag solved the issue.
