Author Topic: Can you also launch NON case sensitive searches?  (Read 2963 times)
TomSamyn
« on: September 18, 2019, 07:44:27 pm »
Not sure if another topic exist yet did not found it in this forum neither on the help pages.
Searches (Find in project) in EA Sparx are by default always case sensitive which makes it hard to rely on.
Is there any way to configure it to have it non case sensitive?
Thanks for all valuable input! Tom
PS. running EA Sparx version 15.0.1508, yet in previous versions same issue
Re: Can you also launch NON case sensitive searches?
« Reply #1 on: September 18, 2019, 07:47:15 pm »
Depends on the database you use. EAP uses Mickeysoft Access and is case insensitive. You might change the collation for other DBs. Ask the DBA of your trust.
