Author Topic: Unable to import xmi file from UModel  (Read 3877 times)
jacewuk
« on: September 24, 2019, 11:23:04 pm »
We are looking to use Sparx instead of UModel and looking to import the class diagrams. However when I try and import any diagram, even a simple class, it doesn't work. Sparx doesn't show any errors and says import is complete but no objects appear in the model/component view.
Simple file shown below, which just has two classes:
<?xml version="1.0" encoding="UTF-8"?>
<xmi:XMI xmlns:xmi="http://www.omg.org/spec/XMI/20110701" xmlns:uml="http://www.omg.org/spec/UML/20110701">
   <xmi:Documentation>
      <contact>www.altova.com</contact>
      <exporter>Altova UModel2019sp1</exporter>
      <exporterVersion>17</exporterVersion>
   </xmi:Documentation>
   <uml:Model xmi:id="U00000001-7510-11d9-86f2-000476a22f44" xmi:uuid="00000001-7510-11d9-86f2-000476a22f44" name="Root">
      <packagedElement xmi:type="uml:Package" xmi:id="U00000003-7510-11d9-86f2-000476a22f44" xmi:uuid="00000003-7510-11d9-86f2-000476a22f44" name="Component View"/>
      <packagedElement xmi:type="uml:Class" xmi:id="U7f31e1ae-9d75-4005-9d96-b2163ba9a5c7" xmi:uuid="7f31e1ae-9d75-4005-9d96-b2163ba9a5c7" name="cl_test1">
         <ownedAttribute xmi:type="uml:Property" xmi:id="U8017a5e2-7ad1-4d45-b8f5-54278647404c" xmi:uuid="8017a5e2-7ad1-4d45-b8f5-54278647404c" name="Property1" visibility="protected" type="U31e41923-f239-4504-b703-1b052f0a8e96">
            <association xmi:idref="U07c05067-14f6-4938-ba73-3821f0402672"/>
         </ownedAttribute>
         <ownedOperation xmi:type="uml:Operation" xmi:id="U8c7e3714-c056-46f4-9a2f-769792b40c0e" xmi:uuid="8c7e3714-c056-46f4-9a2f-769792b40c0e" name="CreateCar" visibility="public"/>
         <ownedOperation xmi:type="uml:Operation" xmi:id="Ubad35397-7056-41de-bc27-bed160a54101" xmi:uuid="bad35397-7056-41de-bc27-bed160a54101" name="UpdateCar" visibility="public"/>
      </packagedElement>
      <packagedElement xmi:type="uml:Class" xmi:id="U31e41923-f239-4504-b703-1b052f0a8e96" xmi:uuid="31e41923-f239-4504-b703-1b052f0a8e96" name="cl_Car">
         <ownedAttribute xmi:type="uml:Property" xmi:id="U16e045ec-3e38-4771-aa53-154291b74a0f" xmi:uuid="16e045ec-3e38-4771-aa53-154291b74a0f" name="Wheels" visibility="protected"/>
         <ownedAttribute xmi:type="uml:Property" xmi:id="Ucb832968-5138-43b0-8f3c-7450da209a16" xmi:uuid="cb832968-5138-43b0-8f3c-7450da209a16" name="Engine" visibility="protected"/>
         <ownedAttribute xmi:type="uml:Property" xmi:id="U8fba3234-91a8-43a9-a892-920675ad8e96" xmi:uuid="8fba3234-91a8-43a9-a892-920675ad8e96" name="Doors" visibility="protected"/>
      </packagedElement>
      <packagedElement xmi:type="uml:Association" xmi:id="U07c05067-14f6-4938-ba73-3821f0402672" xmi:uuid="07c05067-14f6-4938-ba73-3821f0402672">
         <memberEnd xmi:idref="U8017a5e2-7ad1-4d45-b8f5-54278647404c"/>
         <ownedEnd xmi:type="uml:Property" xmi:id="U0d17d0c6-52c6-4506-8b16-c4f3c1c6cfbb" xmi:uuid="0d17d0c6-52c6-4506-8b16-c4f3c1c6cfbb" visibility="protected" type="U7f31e1ae-9d75-4005-9d96-b2163ba9a5c7">
         </ownedEnd>
         <memberEnd xmi:idref="U0d17d0c6-52c6-4506-8b16-c4f3c1c6cfbb"/>
      </packagedElement>
   </uml:Model>
</xmi:XMI>
I have tried changing certain attributes such encoding, model, but nothing seems to work. If I export a sparx model from Sparx and re-import it, it does then work fine. So it must be something specific above that is wrong.
Any ideas?
TIA
Re: Unable to import xmi file from UModel
« Reply #1 on: September 25, 2019, 07:21:53 am »
You could reach for Sparx' support. They are usually quite reactive. Just ask them that you/your company are looking forward to switch to EA but only if you can import your data.
« Reply #2 on: September 25, 2019, 08:57:24 am »
What's blocking it is that the classes are owned by the model, not a package. EA imports everything below the package.
jacewuk
« Reply #3 on: September 27, 2019, 06:00:51 pm »
Thank you, I have managed to import it now
