Author Topic: EA15 - How do I change font size in <<custom table>> ?  (Read 3530 times)
dry
« on: September 25, 2019, 10:51:10 am »
I thought to insert a custom table, for a quick spreadsheet like  ..
But I cannot, at all, change the font size inside it - i.e. in the table itself.  It stays lookslike at default 8.
I tried setting Default Appearance Font Size, set to 14 - nothing.  It does not only not change the font in cells, it doesn't change the heading/name size (element name).
Even when I try print it to PDF, the font size is still small, and if I try to zoom in, it blurs to a bad quality .
How do yo do it ??
« Last Edit: September 25, 2019, 10:52:47 am by dry »
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
Re: EA15 - How do I change font size in <<custom table>> ?
« Reply #1 on: September 28, 2019, 01:22:15 am »
I suppose it is like the Model Views: the font is fixed and you can't change it (by now)
dry
« Reply #2 on: September 29, 2019, 11:05:39 pm »
I'm not sure what you mean.
But on a model graph / view, I can, usually  , change the font - through default appearance - of any element and individually too.
For example, say a (text) Note element. I can change its default appearance's font, which then changes the font the text is displayed inside that Note, on the model view/graph.
