Author Topic: Procedure for upgrading from version 14 to 15  (Read 3943 times)
HLidstrom
« on: September 28, 2019, 12:41:40 am »
I want to upgrade from Sparx EA 14 to 15. I have already downloaded the installers I need but I am not a local admin and will have to tell my IT Support exactly what the steps are. I have spent quite some time now, searching the Sparx site in vain for an instruction, so now I turn to the forum.
I need to know things like - Must I uninstall 14 before I install 15? Will uninstalling 14 also uninstall the add-ons (the MDG packages), or will I need to uninstall each separately? Will the 15 installer also uninstall 14 (and all its MDG packages)?; Can I keep 14 and install 15 in parallel?
HÃ¥kan
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
Re: Procedure for upgrading from version 14 to 15
« Reply #1 on: September 28, 2019, 01:21:13 am »
Just install version 15. It does the uninstall of previous versions. It is just a common installer (next, next, agree, next, next, finish). It keeps you local configuration, so it is not required any additional config.
« Reply #2 on: September 28, 2019, 02:03:35 am »
If you want to keep the previous version all you need to do is rename the program files folder to something other then EA.
HLidstrom
« Reply #3 on: September 28, 2019, 04:46:37 am »
Thank you guys!
This is all I need to know. (For now  ;))
