Author Topic: Specifications list : does not go into sub-packages? How to group into one list  (Read 2525 times)
dry
EA 15 as the Specifications view, where you can open , I think any, folder/package in it, and it lists the contents.
( I think shortcut is Cntrl-0 to open it ..)
One issue i have, say I have "requirements" folder, and inside it i have two sub-packages (yes, a package object) - "essential" and "advanced".   If I open each of these sub-folders/packages in the Specifications list then their contents, individually , are all listed fine.
But if I open the root , the "requirements" folder, then it does not list the requirements - it does not go into the sub-packages or folders.  So I would have to manually go and open those sub-packages in the Spec list.
Is there a flag somewhere to make the Spec view recurse / go into all sub-folders/packages .. ?
Also, i couldn't figure out if it is possible to save / accumulate this spec list - i.e. how can I first say, open "essential" requirements, save the Specs, then open "advanced", and add those into the saved Specs. Each time I re-open that Specs view, it just lists the contents of what element/package I'm opening.
Ideally, I can open anything from different models, and add to this Spec list. I thought that's the idea with that feature but I can't figure out how to use it.
