Author Topic: Final and Abstract classifiers  (Read 17083 times)
Modesto Vega
« on: October 04, 2019, 11:11:40 pm »
If I want to set a class to be an Abstract classifier, I am assuming that I need to set the Abstract property to checked. Is this correct?
If I want a class to be a Final Classifier, a classifier that cannot be specialised/sub-classed. Am I correct to assume that I need to check the Is Root checkbox? The wording of the help for Is Root and Is Leaf is not very clear.
Is Root
Select the checkbox to identify the element as being a root element that cannot be descended from another element.
Is leaf
Select the checkbox to identify the element as being final, so it cannot be a parent for other elements.
Re: Final and Abstract classifiers
« Reply #1 on: October 04, 2019, 11:24:11 pm »
I think it's the other way.
Final = isLeaf
IsRoot would be for something like Object I guess
« Reply #2 on: October 04, 2019, 11:26:26 pm »
UML 2.5 say on p. 99:
The isLeaf property, when true for a particular RedefinableElement, specifies that it shall have no redefinitions.
There is no IsRoot property defined in UML 2.5. So this is Sparx' little secret what it shall be used for.
To make an element abstract tick the Abstract mark in the Details properties section.
« Last Edit: October 04, 2019, 11:29:25 pm by qwerty »
Modesto Vega
« Reply #3 on: October 05, 2019, 12:52:46 am »
Thanks Geert and qwerty, I will settle with Is Leaf and would also love to know what the Is Root Sparx EA secret is for.
Modesto Vega
« Reply #4 on: October 05, 2019, 01:36:29 am »
Scrap that, Is Root makes a class Final Classifier. A class with the Is Root checked cannot have specialised another class.
Not sure about the purpose of "Is Leaf".
« Reply #5 on: October 05, 2019, 03:16:11 am »
That is just nonsense, opposite to what is described in the manual.
« Reply #6 on: October 05, 2019, 10:01:32 am »
Hi Modesto,
I think you may have misunderstood Sparxian.
isRoot, says the class cannot have been specialized from another class.  isLeaf, says the class cannot be specialized from.
« Reply #7 on: October 07, 2019, 09:25:24 am »
isRoot was in UML 1.5 and we haven't got around to removing it yet (there's sure to be someone somewhere using it).
A Class where isRoot is set must not be the source of a Generalization.
A Class where isLeaf is set must not be the target of a Generalization.
Modesto Vega
« Reply #8 on: October 07, 2019, 09:54:56 pm »
Hi Modesto,
Let's see if we can translate Sparxian into normal English.
With isRoot set, a class cannot be the source of Generalization as  per KP reply but can be the target of Generalization. This means the class can be specialised but cannot be generalised, this what I think Paolo is saying. This is very useful to create an ontology model where the root cannot be further generalised.
The UML 2.4.1 specification states
isFinalSpecialization: Boolean
if true, the Classifier cannot be specialized by generalization. Note that this property is preserved through package
merge operations; that is, the capability to specialize a Classifier (i.e., isFinalSpecialization =false) must be preserved
in the resulting Classifier of a package merge operation where a Classifier with isFinalSpecialization =false is merged
with a matching Classifier with isFinalSpecialization =true: the resulting Classifier will have isFinalSpecialization
=false. Default is false.
I find this a bit confusing, but my original understanding it that I need to set isLeaf to True to prevent a class from been further specialised, which is Sparx EA behaviour. Whether, this makes it a Final Classifier I am not sure, let's say I have an ontology like (please note I am aware this may not be the best of examples):
Party (isRoot = True, isLeaf= False)
----Person
----Organisation
--------Internal Organisation (isRoot = False, isLeaf= True)
--------External Organisation
Party cannot be further generalised, intentionally or by accident, and Internal Organisation cannot be further specialised, intentionally or by accident. Which is class is the Final Classifier (Party or Internal Organisation)?
« Reply #9 on: October 07, 2019, 10:07:37 pm »
First you have to give your definition of "final".
A leaf has one final root. A root has many final leafs. Given a tree, and not a graph.
« Last Edit: October 07, 2019, 10:12:00 pm by qwerty »
« Reply #10 on: October 07, 2019, 10:21:43 pm »
Your Internal Organisation would be Final (as used in Java) In C# the same concept is called Sealed
I don't think such an equivalent exists for isRoot (which is not in UML 2.5 anymore anyway)
Modesto Vega
« Reply #11 on: October 07, 2019, 11:23:02 pm »
So qwerty was right in the 1st instance, isLeaf is used to set a class as Final Classifier.
Having said this I am more interested in the isRoot because it prevents further generalisation, accidental or intentional. I think I read the UML quote as meaning that, in this example, Party is the final classifier. I find the UML quote also very Sparxian.
