Author Topic: Generate Documentation: Change order of connectors in fragment  (Read 3300 times)
Hurra
    • Find me at LinkedIn!
« on: October 08, 2019, 12:12:25 am »
Hello!
I have a template:
package>
element>
STUFF
embedded elements>
FRAGMENT
<embedded elements
<element
<packge
and a fragment:
packge>
element>
STUFF
connector>
target>
element>
TABLE
<element
<target
<connector
<element
<package
In the documentation I get everything I want for one exception. Each embedded element, tables its connectors. The order of that table is different for each element sent to fragment.
Can I somehow order this? By name of target-element, target-classifier or target-owner? By anything? Right now the tables are very confusing since it is always in a different order.
Thank you for your help!
always learning!
Re: Generate Documentation: Change order of connectors in fragment
« Reply #1 on: October 08, 2019, 12:23:18 am »
Probably not out of the box. You can report it as a bug, and if you are lucky they'll fix that some day.
In the mean time you can et by using an SQL Fragment.
With an "order by" statement in the query you can define your own preferred order.
Hurra
« Reply #2 on: October 08, 2019, 01:30:48 am »
Thank you!
I made an SQL search as per your recommendation.
always learning!
