Author Topic: Prevent accidental deletes of elements  (Read 2985 times)
mse
« on: October 08, 2019, 01:04:13 am »
We have a composite class that has many properties and over time we had people add many connections between properties within that composition.
Someone accidentally deleted this composite however and now we will need our IT to restore.
How can we prevent this in the future? Is there a way to have more control over that composition class in order to prevent such things?
Our model is a repository model based on SQL Server.
PeterHeintz
Re: Prevent accidental deletes of elements
« Reply #1 on: October 08, 2019, 01:43:05 am »
You could apply locks.
Best regards,
Peter Heintz
« Reply #2 on: October 08, 2019, 01:44:59 am »
Funny. I always call EA's "security" accidental deletion prevention (which it basically is).
« Reply #3 on: October 08, 2019, 03:07:51 am »
You can setup a few things:
- EA Security (with option "Require User Lock to Edit")
- Weekly project transfers to .eap files (to avoid having to restore the whole database)
- Some kind of automated check implemented in an EA-Matic script or an add-in that prevents the deletion of elements. See https://bellekens.com/2015/01/18/prevent-accidental-deletes-with-ea-matic/ for an example.
