Author Topic: Element to attribute relationship in Matrix  (Read 5785 times)
jami
  • ekhm
« on: October 17, 2019, 09:32:51 pm »
Is there any chance to create Matrix Specification that show Elements (Application) in one side and Attributes of Elements (Class) on the other side?
Thx for help.
Re: Element to attribute relationship in Matrix
« Reply #1 on: October 17, 2019, 10:18:13 pm »
No you can't do that. Matrix is only for Element <-> Element
jami
  • ekhm
« Reply #2 on: October 17, 2019, 10:43:04 pm »
Thx for answer.
I'm working on EA12 and I'm guessing that in EA15 something like "New and Improved "Feature to Feature" relationship Matrix and Management" also doesn't support "Element <-> Attribute".
So, I must go to "Suggestions" area :)
« Last Edit: October 17, 2019, 10:44:42 pm by jami »
RoyC
  • Read The Help!
« Reply #3 on: October 18, 2019, 09:45:49 am »
I don't think it is what you want, but this what EA does provide in Release 15.0:
https://www.sparxsystems.com/enterprise_architect_user_guide/15.0/modeling/element_matrix.html
« Last Edit: October 18, 2019, 10:39:32 am by RoyC »
Best Regards, Roy
mse
« Reply #4 on: October 18, 2019, 05:13:43 pm »
I had a very similar problem. I wanted to trace class methods to a requirement. Unfortunately, as other mentioned, you can only trace to the element level i.e. class.
However, I am considering the option of tracing from the Activity specifying the method to the requirement itself.
jami
  • ekhm
« Reply #5 on: October 21, 2019, 07:08:48 pm »
Thx RoyC. Unfortunately, in this matrix the "Type" field cannot be set, for example: "Component" in Source and "Attributes" in Target.
Modesto Vega
« Reply #6 on: October 23, 2019, 04:25:35 am »
Geert is correct, but if you are using an RDBMS repository nothing stops you from trying to achieve some similar with a SQL statement.
jami
  • ekhm
« Reply #7 on: October 29, 2019, 12:07:08 am »
Thanks for the answers. I will try to create these relationships directly on the database.
billf62
« Reply #8 on: November 08, 2019, 11:35:29 am »
It's in ver15, but maybe the Feature Matrix might work for you: Design > Element > Feature Matrix
Hope this helps,
Modesto Vega
« Reply #9 on: November 11, 2019, 08:51:02 pm »
The feature matrix as per build v15.0.1513 (Build 1513) allows you to create a matrix between 2 elements, on one element you could specify operations and on the other attributes.
There are a number of limitations:
  • It is an element to element matrix, unfortunately you cannot choose all elements in a package
  • It works well for Class elements, but it does not work for any element that does not have attributes, operations or receptions
P.S.: Not sure what receptions means in this context, I will need to decipher https://sparxsystems.com/enterprise_architect_user_guide/14.0/model_domains/reception.html.
