Author Topic: I NEED HELP WITH A SQL SENTENCE  (Read 4083 times)
charlyprg
« on: October 18, 2019, 12:18:17 pm »
Hi, I try to create a SQL sentence for a template but I have a error because I use  COALESCE and convert(varchar(90)). I use the enterprise 13 bulit 1310
SELECT
RN.Name as [Name],
RN.Alias as [Padrão],
RN.Note as "Note.Formatted", --(Esta me toco cambiarla por "ObjectNotes-Formatted")
RN.Status as [Status],
 COALESCE((SELECT convert(varchar(90), REL.Name) + char(13) AS [text()]
     FROM t_object REL, t_connector CON2, t_connector CON3
     WHERE CON3.Start_Object_ID = #OBJECTID#
     AND REL.Object_ID = CON3.End_Object_ID
    AND REL.Stereotype in ('BusinessProcess',  'FunctionalRequirement' )
    AND REL.Object_ID = CON2.End_Object_ID
    AND CON2.Start_Object_ID = RN.Object_ID
   FOR XML PATH(''), TYPE).value('.[1]', 'VARCHAR(MAX)'), '') AS [REL]
FROM t_object RN, t_connector CON1
WHERE CON1.Start_Object_ID = #OBJECTID#
AND RN.Object_ID = CON1.End_Object_ID
AND RN.Stereotype = 'BusinessRequirement'
AND RN.Status NOT IN ('StandBy', 'Revisar')
Re: I NEED HELP WITH A SQL SENTENCE
« Reply #1 on: October 18, 2019, 02:28:22 pm »
Which database? What error?
Most of us are not clairvoyant, so you'll have to give us a bit more info.
charlyprg
« Reply #2 on: October 18, 2019, 02:45:20 pm »
Sorry I don´t know a DataBase, how I configure wich database can use?. I don't use a EA in a server, I used only in my computer and it's the first time that I installed the software
charlyprg
« Reply #3 on: October 18, 2019, 03:06:41 pm »
I Understand, how it's the first time that I installed the software in my computer the default database is Access. Thank you!!!
charlyprg
« Reply #4 on: October 18, 2019, 04:02:17 pm »
The correct question is: How I can convert this sentence in SQL in a sentence in Access?
SELECT
RF.Name as [Name],
RF.Alias as [Padrão],
RF.Note as "Note.Formatted",
RF.Status as [Status],
    AND REL.Stereotype in ('BusinessRequirement', 'NonfunctionalRequirement')
    AND REL.Object_ID = CON2.Start_Object_ID
    AND CON2.End_Object_ID = RF.Object_ID
FROM t_object RF, t_connector CON1
AND RF.Object_ID = CON1.End_Object_ID
AND RF.Stereotype = 'FunctionalRequirement'
AND RF.Status NOT IN ('StandBy', 'Revisar')
order by RF.Name
Thanks!!!!
« Reply #5 on: October 18, 2019, 05:24:55 pm »
I'm afraid you'll have a lot of work, and I'm not even sure you can translate this into Access SQL syntax.
Especially the "FOR XML PATH" part is going to be problematic.
Maybe it is easier to setup a local SQL Server instance and transfer your model to that.
« Reply #6 on: October 18, 2019, 06:10:39 pm »
Or you use a script in conjunction with some simple SQL to get the output you need.
« Reply #7 on: October 18, 2019, 06:18:53 pm »
I'm pretty sure the query is used in an SQL template fragment (as "Note.Formatted" gave it away).
Converting an SQL fragment to a script fragment is a big step.
