Author Topic: V15 Scripts do not run  (Read 5505 times)
Greenbolt
« on: October 22, 2019, 12:09:01 am »
Good morning everyone,
I removed V14 and installed V15 and since then I can not execute scripts anymore. Does anyone have any suggestion as to why that could be happening? This happened only with V15 so far and when I downgrade to V14, scripts execute just fine.
Re: V15 Scripts do not run
« Reply #1 on: October 22, 2019, 01:21:37 am »
Maybe you don't have "execute script" rights?
It's one of the newer user security rights, and it's not enabled by default.
Takeshi K
    • Sparx Systems Japan
« Reply #2 on: October 23, 2019, 11:37:46 am »
Hello Greenbolt,
Maybe you can avoid the issue by installing Visual C++ Redistributable for Visual Studio 2015.
https://www.microsoft.com/en-us/download/details.aspx?id=48145
(You need to download 32bit file.)
« Last Edit: October 23, 2019, 11:40:52 am by Takeshi K »
t-kouno
Rich Anderson
    • LinkedIn
« Reply #3 on: October 23, 2019, 03:04:52 pm »
Hi Greenbolt,
This might be related to the issue I reported with EA15 where it was locking.  Sparx has investigated this, contacted me, and confirmed they were able to duplicate the problem..  In my case, EA15 would lock up when my external VB.NET program would start EA.  This does not happen with EA14.
https://www.sparxsystems.com/forums/smf/index.php/topic,43305.msg256831.html#msg256831
Maybe this will help you...
Rich Anderson
Urgnt Limited
peterc
« Reply #4 on: October 24, 2019, 08:16:11 pm »
I had the same and with some diagnosis from Sparx I identified two DLLs that were missing: MSVCP140.dll and VCRUNTIME140.dll.
I found those elsewhere on my computer and copied them to the EA install folder, resolving the issue.
I've also since had a follow-up e-mail from Sparx:
The issue has been confirmed and will be investigated further by our development team. It looks like mozjs-63a1.dll requires the DLLs that you mentioned.
As a workaround we recommend downloading the x86 VS 2017 runtime files from Microsoft.
https://support.microsoft.com/en-us/help/2977003/the-latest-supported-visual-c-downloads
Takeshi K
« Reply #5 on: October 24, 2019, 08:34:29 pm »
Hi all,
Just for your information, MSVCP140.dll and VCRUNTIME140.dll are included in the Visual C++ Redistributable for Visual Studio 2015, which I mentioned in the above post.
Copying the files might works fine, but it is better to use Microsoft official installer to avoid further missing related files.
t-kouno
