Author Topic: MDG defined tagged values don't show up in the properties  (Read 3549 times)
« on: October 22, 2019, 09:55:45 pm »
If you use MDG defined tagged values on attributes, they don't show up in the properties window, not in the pane Attribute and not in the pane "Tags"
Only if you open the new attribute dialog, and select "Tagged Values" you can actually see the tagged value with it's content
MDG defined tagged values have format: MDGName::TagName
Tested on version 15.0.1512
Reported
