Author Topic: Can connection to eapx file be refreshed after network disruption?  (Read 5920 times)
HLidstrom
I was working with my Sparx EA V.14 client on an EAPX file stored on a shared drive when the network connection went down temporarily.
After the network was restored, I selected one of the diagrams I had open already.
Now I get the message below and it just comes back again and again when I click OK.
Is there a way to make the Sparx EA client refresh its connection to the EAPX file?
Enterprise Architect
DAO.Database [3078]
The Microsoft Jet database engine cannot find the input table or query 't_package'.  Make sure it exists and that its name is spelled correctly.
[ OK ]
Håkan Lidström
HLidstrom
Re: Can connection to eapx file be refreshed after network disruption?
« Reply #1 on: October 30, 2019, 04:12:18 am »
Actually,
The message box changes, so Sparx EA isn't completely hung.
I also get message
DAO.Database [3078]
The Microsoft Jet database engine cannot find the input table or query 't_diagram'.  Make sure it exists and that its name is spelled correctly.
[ OK ]
That is, for every box about t_package, I get a varying number of t_diagram messages.
Maybe I just have to click through a thousand or so messages boxes and everything will be fine?
Thanks again
- Håkan
« Reply #2 on: October 30, 2019, 04:29:34 am »
Mickeysoft Access is not designed to be used over a network at all. Consider using a *real* database instead.
« Reply #3 on: October 30, 2019, 05:48:14 pm »
Just kill EA (task manager) and restart.
Luckily, the only thing you would have lost is the diagram layout that had not been saved.
HLidstrom
« Reply #4 on: October 31, 2019, 12:35:34 am »
Thank you guys.
Move to real DB is in the works. (Just takes a little longer than I would like.) And as Geert says, only unsaved diagram changes are lost. I can confirm.
« Reply #5 on: October 31, 2019, 08:50:50 am »
Just be extra careful. Jet can leave corrupted db files in situations like a network cut. Double check your backup routine, run an integrity check and run a compact/repair.
