Author Topic: SqlQuery from JAVA API returning nothing  (Read 3343 times)
derekwallace
« on: August 23, 2012, 06:23:16 pm »
Im using the JAVA api to export information from EA.
Im now extending it and want to use the Repository command SqlQuery.
Using the EA GUI i can construct the SQL query in the Model Search window and it runs correctly.
Trivial example here.
SELECT t_object.ea_guid AS GUID FROM t_object
When i try to use the JAVA API i get nothing back. here is my script.
org.sparx.Repository oRepos = new org.sparx.Repository()
oRepos.OpenFile(sReposName);
String sSqlQuery  = "SELECT t_object.ea_guid AS GUID  FROM t_object";
String sTmp = oRepos.SQLQuery(sSqlQuery);
System.out.println(sTmp);
What i get back in sTmp is this. (empty xml)
<?xml version="1.0"?>
<EADATA version="1.0" exporter="Enterprise Architect">
</EADATA>
Ive tried putting a broken SQL command in and i still get same back the same.
String sSqlQuery  = "SELECT t_object.XXXXXea_guid AS GUID  FROM t_object";
Any suggestions?
Thx
Derek
« Last Edit: August 23, 2012, 06:28:03 pm by derekwallace »
derekwallace
Re: SqlQuery from JAVA API returning nothing
« Reply #1 on: August 23, 2012, 06:33:22 pm »
found issue in my code. It works fine.
My error was that i was constructing the SQL Search on multi lines.
             sSqlQuery  = "SELECT";
             sSqlQuery += "   t_object.ea_guid AS GUID,";
             sSqlQuery += "   t_object.name AS Name,";
             sSqlQuery += "   t_object.Object_Type AS Type,";
             sSqlQuery += "   t_object.Author AS Author";
             sSqlQuery += "FROM ";                                 <----- this line was issue.
             sSqlQuery += "   t_object";
I had to put a space in front of the FROM.
             sSqlQuery += " FROM ";
