Author Topic: Bug Tracker?  (Read 3793 times)
BJTim
Bug Tracker?
« on: October 31, 2019, 08:00:27 pm »
I've opened several bug reports regarding version 15.x (e.g. Document windows are not working, reporting all elements in a diagram is not working etc.).
None of those bugs is fixed until now.
I accept, that at Sparx you are busy, and not every bug is fixed soon, but as there are even some bugs from version 14.1 that are not fixed (e.g. task effort numbers change in xmi-Export/Import), I fear that you are overloaded.
That's why I vote for a bug tracker to have more transparency in the resolution process (beside more care about changing and removing working features).
The tracker also should allow for a voting about how urgent a bug is, and maybe you give each license 10 votes per year.
Currently we are often wondering, if we should go back to version 14.x to have some features working again. A pitty it would be, but what can we do?
Re: Bug Tracker?
« Reply #1 on: October 31, 2019, 08:53:51 pm »
This is an ongoing discussion ever since. https://app.assembla.com/spaces/enterprise-architect/tickets/realtime_list is a tracker I did set up for myself (almost 10 years ago) when I was at the same point as you. I stopped maintaining the list later as I noticed: no progress. I just gave up hope. Pretty sure you will still find some of the bugs I reported in the current EA version (which I don't use because it only has "new features").
P.S. I just had that "Visualizations to Wow Your Stakeholders" mail in my inbox. I don't want to WOW them. I want to WORK WITH them!
« Last Edit: October 31, 2019, 08:56:04 pm by qwerty »
