Author Topic: Getting/setting a diagram property on an element using script?  (Read 4157 times)
Jayson
« on: November 06, 2019, 10:00:27 am »
Hello all
I have a bunch of stereotypes that have diagram properties within them <<diagram property>> and am trying to get and set their values within Sparx scripting.
Given that their scope is limited to diagrams, I am assuming that I need to access them via the Diagram Object rather than the Element Object.
However, looking at the object model for Diagram Objects I cannot for the life of me see a natural way to do this.
Is this possible to do this?
Cheers
Jays :-)
Aaron B
Re: Getting/setting a diagram property on an element using script?
« Reply #1 on: November 06, 2019, 10:30:48 am »
Can you be more specific about what kind of properties you are trying to get/set? If you are trying to change some aspect of the appearance of an Element on a specific diagram, then yes, DiagramObject would be the best place to look.
https://sparxsystems.com/enterprise_architect_user_guide/15.0/automation/diagramobjects.html
Jayson
« Reply #2 on: November 06, 2019, 10:38:45 am »
Hey Aaron
Thanks for your reply!
I have added custom diagram properties to my stereotype by applying the <<diagram property>> stereotype to one of the element stereotype's attributes by following the example given in the link below.
These custom diagram properties have a scope restricted to a specific diagram, meaning that you can set the same property to two different values on different diagrams.
However, what I can't figure out is how to access them using the scripting language.
Cheers :-)
https://www.sparxsystems.com.au/enterprise_architect_user_guide/14.0/modeling_tools/query_methods.html
