Author Topic: Hiding Diagram Objects on a diagram  (Read 14896 times)
Jayson
« on: November 06, 2019, 10:13:02 am »
Hey all
My understanding has always been that (unlike diagram links), there is no "IsVisible" attribute or equivalent that can be used to suppress a diagram object from being visible on a diagram.
However, if I look at the link below, it lists Elements as having the following two properties that can be access from shape scripts:
IsVisible, and
Visibility
So the obvious answer, is "what gives"?
https://sparxsystems.com/enterprise_architect_user_guide/14.0/modeling_tools/displaying_element_properties.html
Cheers
Jays :-)
Aaron B
Re: Hiding Diagram Objects on a diagram
« Reply #1 on: November 06, 2019, 11:11:29 am »
IsVisible I think is mainly for processing child elements. See Example 3 on the following page about custom compartments:
https://www.sparxsystems.com/enterprise_architect_user_guide/15.0/modeling/add_custom_compartments_to_ele.html
I'm not 100% sure what the Visibility property is though. At first I thought it might be the Scope (Public, Private etc) since that sometimes gets referred to as Visibility in other places, but doesn't seem to be the case here.
« Reply #2 on: November 06, 2019, 11:26:14 am »
Visibility may be related to the [Ctrl+F9]|Objects|Advanced,  It seems to be related to Element Visibility.
Thomas, in his excellent book, lists Visibility as "Always NULL?!"
« Reply #3 on: November 06, 2019, 12:04:17 pm »
Just guessing: connectors can be set invisible. Maybe that property only works on connectors being set invisible. But then: why evaluate it in a shape script if the connector is invisible anyway? So many strange things in EA. Another guess: it's just a wrong documentation.
Jayson
« Reply #4 on: November 06, 2019, 12:13:00 pm »
I have wondered if that is the case.
Do you know if I can access the IsSelectable property of an element from the shape script?
The same webpage doesn't list as being accessible, which seems strange to say the least.
I have added a diagram property called "Visible" to my stereotypes and modified the shape script to show nothing when this is set.
However, I cannot find a way to set diagram properties of individual diagram objects from scripting.
As a backup, maybe I can set the IsSelectable switch from scripting and then modify the shape script to display nothing when THAT switch is set?
But to do that I need to be able to detect it in the shape script!
Cheers
Jays :-)
« Reply #5 on: November 06, 2019, 04:33:45 pm »
Hi Jays,
IIRC, the User Specific Diagram Properties end up in the ObjectStyle column of t_diagramobjects.  They aren't available directly from the API, you need to parse the column.
If you search for "User Specific Diagram Propert" you'll find a lot of stuff on how they need to be improved.
Jayson
« Reply #6 on: November 06, 2019, 04:39:36 pm »
Hey Paolo
Thanks for that! Am I able to get and set the contents of that column from the API somehow?
I'm not adverse to a little bit of parsing if I can get hold of the data in the column.
Cheers
Jays :-)
« Reply #7 on: November 06, 2019, 05:28:37 pm »
Hey Paolo
I'm not averse to a little bit of parsing if I can get hold of the data in the column.
Cheers
Jays :-)
DiagramObject.Style  Search for DiagramObject Class in the Help.
[Edit: They're actually in Diagram.StyleEx referencing a DUID in DiagramObjects.  See later posts from KP]
« Last Edit: November 07, 2019, 03:57:52 pm by Paolo F Cantoni »
« Reply #8 on: November 06, 2019, 07:47:30 pm »
See p. 58 of my Inside book: DiagramObject.StyleEx has a CSV value NSL=1/0
Jayson
« Reply #9 on: November 07, 2019, 05:32:01 am »
Hey Thomas
I have ALL your books which I bought a good number of years ago now.
Looks like you must have changed it from the original as I can't see NSL in there anywhere.
Unfortunately I lost my LeanPub credentials when I left my last company but never mind my current company can give you another generous donation so I can get the updates  ;)
Jayson
« Reply #10 on: November 07, 2019, 06:40:56 am »
Alrightie, so you should be a handful of dollars richer as I have updated my version of Inside EA.
Looking at page 58, it states that NSL is "1/0 corresponding to the context menu setting Selectable".
However, what I am after is the ability to read from and write to the User Specific Diagram Properties that I define as belonging to a particular stereotype.
Please see the link below for an example of what I am after.
https://sparxsystems.com/enterprise_architect_user_guide/14.0/modeling_tools/query_methods.html
In this scenario, I am looking for a method for reading and writing to the Is Red property for the Red Flag stereotype.
Cheers :-)
« Reply #11 on: November 07, 2019, 08:12:19 am »
Hey Thomas
Send me a PM and I mail you an update.
« Reply #12 on: November 07, 2019, 08:15:07 am »
Hmm. Late for me already. But diagrams don't have stereotype properties (aka TVs) in V13.5. Are there in later versions?
Jayson
« Reply #13 on: November 07, 2019, 08:45:58 am »
Hey Thomas
The properties I am talking about belong to Element Stereotypes (please see the bottom of the page below).
These are properties that can have different values on different diagrams for the SAME element.
Therefore, I am assuming that they belong somewhere to the DiagramObject class but can't find where to access them.
It is driving me crazy! ;-)
Cheers
Jays :-)
« Reply #14 on: November 07, 2019, 09:20:26 am »
I haven't dealt with these diagram properties. Not sure if V13.5 has them. I do have V14 but actually work just with 13.5. Will have a look tomorrow.
P.S. I tried locating something in the help that tells how to create that in a MDG: of course no luck. That picture just looks like something I never saw before. Es ist zum Knochen kotzen (don't try to translate, it's sort of a curse. Nothing to beep away, though)
P.P.S: Don't try to find these. It's anyway part of the MDG stuff which is held in memory. No access to us dumb users. If someone can give me a hint where to find info about these <<diagram property>> attributes: thanks in advance.
« Last Edit: November 07, 2019, 09:38:30 am by qwerty »
