Author Topic: RTF Generation Formatting...  (Read 5162 times)
jmcdonnell
« on: August 14, 2012, 11:40:30 pm »
Hi all,
I'm having some serious trouble in getting EA to do what I want it to!
When generating .rtf documentation I want my document to format in the following manner:
[highlight]Title blurb
BPMN data flow diagram 1
Associated requirements
BPMN data flow diagram 2
etc...[/highlight]
I get as far as the first diagram then ALL requirements drop in then nothing else...
Any advice will be greatly appreciated!
Joe
Ian Mitchell
Re: RTF Generation Formatting...
« Reply #1 on: August 15, 2012, 02:04:08 am »
Have a look at eaDocX. Much simpler
www.eaDocX.com
www.theartfulmodeller.com
« Reply #2 on: August 15, 2012, 08:45:21 am »
No problem to do that in EA.
You want a template like the following.
Title Blurb
[highlight]package >[/highlight]
{Pkg.Name}
[highlight]diagram >[/highlight]
{Diagram.DiagramImg}
[highlight]element >[/highlight]
{Element.Name}
[highlight]< element
< diagram
< package[/highlight]
Put anything you need in the element and diagram sections.
OpenIT Solutions
« Reply #3 on: August 29, 2012, 03:04:16 am »
I suspect it want be quite as simple as indicated. I'm guessing you have a BPMN diagram and that you have either added embeded Requirements to each Activity (using the Rules->Requirements sheet in the Activity property sheet) or formed a relationship (should be a Realisation) between your Activities and a Requirement object.
If the first is the case you will need to add the
Package -> Element -> Requirement
the second, add
Package -> Element -> External Requirement
to your template.
