Author Topic: "Unspecified error" when opening an MYSQL repository  (Read 7883 times)
JohnE
« on: November 22, 2019, 12:58:42 am »
Hi All,
We have an MySQL database setup and our model transferred to the database.
We are in the early adoption stage and another Architect and I can connect and open up the repository successfully and we have been using this for almost a month now.
We are trying to on-board another Architect, he is getting the above error.
We are using EA 15.0.1510 and the 32bit MySQL ODBC driver. When setting up the driver it connects successfully using the 'Test Connection' but the error occurs when configuring SparxEA to use this connection.
A brief search has indicated the use of the 64bit driver can cause this but I can confirm we are using the 32bit driver.
Any help appreciated.
John
Re: "Unspecified error" when opening an MYSQL repository
« Reply #1 on: November 22, 2019, 05:16:49 am »
EA is pretty particular when it comes to MySQL driver and ODBC settings.
Check the page in the manual and check both version and each of the mandatory settings.
JohnE
« Reply #2 on: November 28, 2019, 09:07:18 pm »
Hi All,
We are not having any luck I am afraid.
I can confirm a successful MySQL driver connection to the database, but still cannot get Sparx to use that connection to open the repository.
I have double/triple/quad-ripple checked the guide and I have tried to copy the connection string from my laptop to the other laptop but still receive the same error.
Guess I'll try raise a support ticket.
John
« Reply #3 on: November 28, 2019, 10:23:11 pm »
You need to mail Sparx support. This is just a user forum.
