Author Topic: restrict use stereotypes to other stereotypes  (Read 3297 times)
Palm
« on: November 22, 2019, 09:50:57 pm »
I created a UML classdiagram profile and a related MDG and toolbox, which is working correctly. I created several stereotypes for classes and several for attributes. What I want now is that certain stereotypes on attributes may only be used in classes of specific stereotypes. So restricting attribute stereotypes to specific class stereotypes. Is this possible?
Paul
Modesto Vega
Re: restrict use stereotypes to other stereotypes
« Reply #1 on: November 22, 2019, 11:39:40 pm »
Not sure I follow you, Class stereotypes should only be applicable to classes and Attribute stereotypes should only be applicable to attributes providing you have extended the right metaclasses.
Palm
« Reply #2 on: November 22, 2019, 11:58:47 pm »
Yes you are right in that respect. But my question is different. I have created attribute stereotype <<X>> and two Class stereotypes <<Y>> and <<Z>>.
I want the attribute stereotype <<X>> only te be applicable to attributes of a class of stereotype <<Y>> and not of type <<Z>>.
« Reply #3 on: November 23, 2019, 12:30:21 am »
Metamodel constraints might be the solution, but I don't know if it works for the ownership relation between attributes and elements.
philchudley
« Reply #4 on: November 23, 2019, 01:53:34 am »
I have just conducted some experiments using metaconstraints, which I agree with Geert as the approach that should work
The obvious candidate for the umlRole tag is ownedAttribute
This certainly has no effect when adding stereotyped attributes to stereotyped classes, (as indeed do any other umlRoles for example owner)
Reading the user guide, it states this constraint is typically used to validate nesting during Model Validation, I tried Model Validation … guess what? No errors no warnings
I suppose a custom validation is required.
Sorry I could not be of more help, but if anyone does come up with an answer that does not involve coding or scripting (these can provide a psot validation of course), then I would very much like to know
All the best
Phil
Models are great!
