Author Topic: V15 - User Tools Ribbon not pupulated  (Read 3720 times)
DigitalMechanic
« on: November 23, 2019, 03:04:39 am »
Hi folks, I'm using v15 Trial (Corporate) to test feasibility and I've setup an ODBC connection so I can connect to database.  Following the documentation https://sparxsystems.com/enterprise_architect_user_guide/14.0/model_repository/setupmysqlodbcdriver.html  in step 1 it says to use the 'Configure > User Tools > ODBC Data Sources' ribbon option" but my User Tools ribbon is empty...
What am I missing?
-DM
Digital Mechanic
Re: V15 - User Tools Ribbon not pupulated
« Reply #1 on: November 25, 2019, 09:55:28 am »
Not sure why that's empty. It is customizable, but the default should contain what you want.
As for setting up a data source, the only trick is to use the 32 bit version. So you need to run C:\Windows\SYSWOW64\odbcad32.exe
RoyC
  • Read The Help!
« Reply #2 on: November 25, 2019, 10:10:59 am »
See if the ribbon options have been edited. Select the Start > Desktop > Workspaces > Ribbon Sets > Manage Ribbon Sets ribbon option to display the Workspace Layout dialog and then click on the System Default ribbon set. On the Configure Ribbons panel of the dialog, expand the Configure set and check whether the User Tools checkbox is selected or not. If it is not selected, click on it to add a tick to the checkbox.
Best Regards, Roy
