Author Topic: SysML vs. Design Description  (Read 2795 times)
CaverViking
« on: November 27, 2019, 03:01:13 am »
Hi!
I am using EA and SysML to describe my medical device. I have created a block diagram. I would like to describe each block with text and then generate a document that contains the block diagram and the description for each block.
Q1: Where/ how in EA should I capture the text description for each block?
Q2: Is there a good template that I can use for design description/ specification?
Q3: Does SysML specify where to capture the description? Should the description be captured in a internal block diagram for each block? Should blocks always be described by other diagrams instead of text?
Thank you
Uffe
Re: SysML vs. Design Description
« Reply #1 on: November 27, 2019, 03:55:11 am »
Hello!
  • Q1: Where/ how in EA should I capture the text description for each block?
    In the block's Notes property. If there's a lot of text, consider a linked document.
  • Q2: Is there a good template that I can use for design description/ specification?
    The supplier-provided templates are generally not worthwhile, you need to create your own.1
  • Q3: Does SysML specify where to capture the description? Should the description be captured in a internal block diagram for each block? Should blocks always be described by other diagrams instead of text?
    Not sure about best practice wrt SysML, and I also suspect the answer is "it depends." But perhaps someone else has a better one.
1Or get a consultant in hint hint. :)
/Uffe
bknoth2
« Reply #2 on: November 27, 2019, 04:08:43 am »
I suggest that as soon as you have a few blocks described and diagrams drafted that you try generating a document. That process will help you understand how you want to organize the model and where you want to put the descriptive information, not to mention the challenges of generating documentation.
