Author Topic: Import from ODBC doesn't work for new check constraints  (Read 3733 times)
« on: November 29, 2019, 11:46:59 pm »
I'm doing a database compare, and I see some new check constraints in the database that are not in EA.
After clicking "Set Import All" and "Import from ODBC", my new check constraints are not added to the model.
Doing a full ODBC import (with synchronize) does create the new check constraints
I have the same problem with updated indexes, and new unique constraints.
I'm connected to an SQL Server 2017 database using EA  v15.0.1513
Reported
Modesto Vega
Re: Import from ODBC doesn't work for new check constraints
« Reply #1 on: November 30, 2019, 01:32:51 am »
Are you using the ODBC driver or the SQL Server Native Client? If an ODBC driver could you try using the SQL Server Native Client?
I have this vague recollection of Sparx doing something weird with constraints, including foreign keys and check constraints, using the ODBC driver. But cannot remember the exact details.
« Reply #2 on: November 30, 2019, 03:06:33 am »
SQL Server native client 11.0
