Author Topic: Make your own Archimate MDG or buy from you :)  (Read 29091 times)
Re: Make your own Archimate MDG or buy from you :)
« Reply #15 on: December 19, 2019, 02:15:41 pm »
Hey, I didn't say thanks to myself... But you're welcome.
The good news is you won't need it as the non-rectangle shape will become the standard one in EA.
« Reply #16 on: December 19, 2019, 09:10:50 pm »
Whoa. The other thread from 2014 where I posted recently has made it to production. Too bad I won't see it in 13.5 :-/
Ian Mitchell
« Reply #17 on: January 07, 2020, 03:59:14 am »
Declaration of interest - I'm the author of Model Expert.
If you're using mostly a sub-set of Archimate, then an alternative approach is to first create some models that you're happy with, then use Model Expert to reverse-engineer them into a 'Reference (meta) Model', which you can then apply to new bits of model. Meta-model rules are applied real-time, and the Ref Model is saved in EA, so can be updated quickly and changes re-deployed.
There's also an option to generate a simple MDG so that diagrams each have the correct set of items in the toolbox  - either Archimate stuff, UML, or anything else.
Might save you some time, especially of your modelling style is evolving.
see www.eadocx.com/modelexpert
www.eaDocX.com
www.theartfulmodeller.com
steen.jensen
« Reply #18 on: January 07, 2020, 10:13:15 pm »
Thanks Ian.
Im going to check it out :)
bellawatson492
« Reply #19 on: January 18, 2020, 10:13:22 pm »
I suggest you to try EA 15.1 Beta, its good than others, I hope you will also find it better than others.
