Author Topic: V15 - ConstLayoutStyles causing problem with .Net 4  (Read 4919 times)
« on: December 20, 2019, 05:47:37 pm »
I haven't touched my Diagrammer C# code in over a year but due to change of "gig", need to recompile in a new environment.  I've had to move up to .Net 4 (I think because the later Interop.EA.dll requires that).  However, I'm getting the following message from the C# compiler:
Severity   Code   Description   Project   File   Line   Suppression State
Error   CS1752   Interop type 'ConstLayoutStyles' cannot be embedded. Use the applicable interface instead.   <project>   <path>\<file>   389   Active
(where <project>   <path>\<file> have been removed...)
A sample code that worked was:
Layout(
ConstLayoutStyles.lsCrossReduceAggressive
+ ConstLayoutStyles.lsCycleRemoveDFS
+ ConstLayoutStyles.lsLayeringOptimalLinkLength
+ ConstLayoutStyles.lsInitializeDFSOut
+ ConstLayoutStyles.lsLayoutDirectionDown
, s_PROCESS_NAME
); //ONLY layout if inserted....
Searching for a solution implies that I need to set the Embed Interop Assembly property to false for the project, but I can't seem to find it.  Is there "an applicable interface" instead?  The documentation on the Sparx site for ConstLayoutStyles doesn't imply that.
HELP!!!
Re: V15 - ConstLayoutStyles causing problem with .Net 4
« Reply #1 on: December 20, 2019, 05:51:31 pm »
Paolo,
Check your References for Interop.EA
Then in the properties of that set "Embed Interop Type" to False
It's not specific to ConstLayoutStyles. You would run into other issues even if you didn't use that enumeration.
« Reply #2 on: December 20, 2019, 07:07:28 pm »
Paolo,
Thanks, Geert!
That did the trick!  Looks like this was the only enum I'm using that suffers from that problem.
Avagoodweegend  as we say in Oz!
