Author Topic: Glossary document template using fragments  (Read 5059 times)
Modesto Vega
« on: December 21, 2019, 03:56:12 am »
I am trying to create a Glossary documentation template with a section per type. It does not seem to be possible doing this through the Model\Glossary section on the template designer as I cannot find a way of grouping types or filtering just one glossary term type.
I looked inside my Sparx box of tools/tricks and concluded that I may be able to do it using Fragments. Fragments allow me to separate glossary term types into sections but I have hit a very annoying problem: the meaning column is rendered with all the formatting markup visible, the text formatting is not applied. Needless to say that if I use the Model\Glossary section on the template designer, everything renders fine.
Have i missed something?
Re: Glossary document template using fragments
« Reply #1 on: December 21, 2019, 04:21:30 am »
Are you using SQL fragments?
In that case you have to do something like (in SQL Server)
select note as [Description-Formatted] from t_object
and in the template you use
{Description.Formatted}
This will tell EA that the field contains formatting so it gets rendered correctly.
For script fragments that works a little bit differently.
Modesto Vega
« Reply #2 on: December 23, 2019, 11:39:12 pm »
Thank you Geert, I am using SQL fragments and this solves the problems, much appreciated.
Is this documented anywhere? Or, is it knowledge embodied in the Sparx community, in this case you?
Season greetings!
« Reply #3 on: December 26, 2019, 08:20:44 pm »
Season greetings!
Yes, you should find that information in the help page about SQL Fragments.
