Author Topic: v15 - SetPenWidth and DrawNativeShape  (Read 5494 times)
« on: December 24, 2019, 01:16:42 pm »
We've changed or shapescripts so that they don't usually change the pen width and THEN try to draw the native shape.  However, we're trying a new one out and it seems that setting the pen width has NO effect on drawing the native shape.  Setting the pen colour DOES, however.  Is it my failing memory that it used to affect the native shape?
Can anyone confirm or deny?
Should it?  I would have thought so, especially as Colour does AND you can set the width manually.
Thoughts?
« Last Edit: December 24, 2019, 01:18:39 pm by Paolo F Cantoni »
Re: v15 - SetPenWidth and DrawNativeShape
« Reply #1 on: December 24, 2019, 06:54:47 pm »
I ran into the very same issue. I did not report it (futile, you know).
« Reply #2 on: January 02, 2020, 02:49:16 pm »
It may be a New Year on Planet Sparx, so I reported it...
(although I had to use the simple Bug report form.  The Registered user forms are dead at present)
« Reply #3 on: January 02, 2020, 03:56:24 pm »
Are you logged in to the registered section? The page is blank while I get prompted for credentials. If I provide them they show normally, if I cancel I get a nice 401 error page.
« Reply #4 on: January 03, 2020, 01:13:13 pm »
Hi Eve,
I don't get asked for credentials, so I assume I'm logged in...
« Reply #5 on: January 03, 2020, 01:15:30 pm »
FWIW, Setting LineStyle also doesn't have any effect (in Nativeshape).  But I can't remember if it used to.
« Reply #6 on: January 03, 2020, 04:48:05 pm »
Can you get to https://sparxsystems.com/registered/index.html?
Based on what I've seen and you've described it sounds to me like something on your end is blocking the prompt for credentials. What browser are you using? Are you using plugins?
« Reply #7 on: January 04, 2020, 12:03:45 pm »
Yes, that's what I started to think, after your last response.
I can confirm I DON'T get credentials on the above page, so I'll start checking what's happened at this end.
