Author Topic: Class and its realised Interface - SQL query  (Read 3136 times)
Evandro
« on: January 11, 2020, 04:44:19 am »
Hi there, I'm trying to query my model in order to get a table with two columns: on with the name of the class and the other with name of the interface realised by the class. First of all, is there a built-in search of this kind or should I build a custom SQL query? In this second case, has anyone done anything similar before? Should I use End_Object_ID and Start_Object_ID of the t_connector table?
Re: Class and its realised Interface - SQL query
« Reply #1 on: January 11, 2020, 07:47:51 am »
Yes, you need the t_connector table WHERE connector_type = "Realisation" and JOIN t_object AS o1 WHERE o1.object_id = Start_Object_ID (or if your EAP gets hickups on JOIN just a plain WHERE.
