Author Topic: New to EA from MagicDraw  (Read 18905 times)
Blumi
« on: January 15, 2020, 06:11:20 pm »
I am new to Enterprise Architect. I have much experience in MagicDraw/Cameo Systems Modeler since I have been using it during my studies and at my former work place.
I am using EA as SysML-Modeler since I want to build rather systems than software. EA and CSM have different modeling principles and architectures. I have several questions:
   - How do I adjust the SysML-Blocks with stereotypes?
      ○ I want to create several custom types to support a method we are working with (Processes from blocks with actions inside, working positions from SysML-actors, functions from blocks, etc.)
      ○ How could I create a SysML-type User Story? Which includes the fixed values of "As"…"I want to"…"so that"…" and tag acceptance criteria to it?
      ○ I have found this article on the knowledge base: https://sparxsystems.com/enterprise_architect_user_guide/14.0/modeling_tools/non-uml_metatypes.html however I cannot find the "<<profile>> Stereotype"
      ○ How do I change the icon of a custom stereotype?
   -  How do I make sure, that an entity exists only once?
      ○ At the moment I can have several blocks with the same name in a model
      ○ For our method it crucial to identify equal functionality
   - How do I visualize e.g. texts of requirements in list view?
That should be all for now. I am very much looking forward to your answers.
Cheers,
blumi
Re: New to EA from MagicDraw
« Reply #1 on: January 15, 2020, 06:30:03 pm »
Hi Blumi,
Welcome to the wonderful world of planet Sparx. :o
That's a lot of questions at once.  ;D
I'll try my best to answer some of them.
Best place to start is here: https://www.sparxsystems.com/enterprise_architect_user_guide/15.0/modeling/umlprofiles_2.html
Make sure to pay special attention to this page https://www.sparxsystems.com/enterprise_architect_user_guide/15.0/modeling/non-uml_metatypes.html which deals with extending existing stereotypes (like SysML)
There are two starter models available for UML profiles. The usage of these should be mentioned if you follow the help about UML profiles step by step
Use the profile helpers to edit the details of your stereotype.
There is the icon (which is used on toolboxes and project browser). Browse to select a bmp file (color 192.192.192 is used as transparant)
also make sure you set a metatype, or the icon won't work.
For the visualization on the diagram you can write your own shapescript.
Either write an SQL Search that returns duplicates, or write an add-in to prevent duplicates to be created.
Try the specification manager view. That is developed exactly for that purpose.
Blumi
« Reply #2 on: January 15, 2020, 10:46:20 pm »
Hi Geert,
thank you first of all!
Okay, I think did not quite get the "MDG Technology Builder" in the tutorial. It is a bit tricky that this function is not included out of the (model)-box.
Regarding the SQL-Part:
Is there no easier way other than using a script? Do you know if someone else has run into this issue before?
Last point: I was not all too clear about my question.
In CSM you are able to use a generic table, which allows you to create very unique views on a type (requirement, block, action, etc.). I am looking for a similiar feature in EA. I mean this feature over here:
https://docs.nomagic.com/display/MD190/Generic+table
Thank you again very much!
Cheers,
Blumi
« Reply #3 on: January 16, 2020, 06:53:13 pm »
MDG Technology builder is an MDG technology that comes out of the box with the installation.
SQL searches are the easy way  ;D
We don't really have something like the generic table, but the model view charts may be the things that resemble it most.
https://www.sparxsystems.com/enterprise_architect_user_guide/15.0/model_publishing/define_a_model_view_chart.html
Again, you'll need to write an SQL Query to get the data to show up.
