Author Topic: list of profiles does not show up.  (Read 3810 times)
Palm
« on: January 16, 2020, 09:57:22 pm »
I have a problem selecting stereotypes for a UML element.
When selecting a stereotype for for instance a uml::class, in the stereotype select window normally a list of profiles to chose from shows up. This list was always very extensive and included my own imported MDG's. Now only a very limited list showes up and not including my MDG's. How is that possible? Have I changed something in the EA specs? When I open the MDG Technologies window, all the available profiles do show up and are active. But as explained they do not show up in the list of stereotype profiles.
I am almost thinking that there is something wrong with my EA installation.
Has any body an idea?
Paul
Re: list of profiles does not show up.
« Reply #1 on: January 17, 2020, 12:43:26 am »
You probably selected a perspective that hides these profiles.
Palm
« Reply #2 on: January 17, 2020, 01:35:27 am »
Hi Geert,
Great! It works. Thanks. I had in fact no particular perspective chosen, which normally is not an issue. All were active, which is default. What I did was a reset of Global Perspectives and the job is done. It works as before. I had this issue for more than a year!!!
Paul
