Author Topic: Sparx EA 15.1 UML-Profile/MDG Creation not working properly  (Read 3678 times)
mschmitz
« on: January 28, 2020, 07:47:00 pm »
Hi!
I started creating an UML-Profile using Sparx EA 15.0 Build 1513. I used the "meta-constraint"-Connector to define some type and class behaviour. After updating the EA to 15.1 (tested all Builds up to 1526) I'am not able to use the "meta-constraint"-Connector between stereotypes anymore. I have tested on some colleagues maschines facing the same problem. Are there already other people having such problems? When can this be fixed?
Kind regards! Markus
Re: Sparx EA 15.1 UML-Profile/MDG Creation not working properly
« Reply #1 on: January 28, 2020, 09:06:13 pm »
Markus,
What do you mean by "not able to use meta-constraint"?
What happens if you try?
I just did a quick test and this is what i noticed
- It's not an option in the quicklinker
- When you have "Strict Connector Syntax" on EA refuses to create one between two stereotype
- It works when using the connector from the toolbox with Strict Connector Syntax off.
Seems like a bug to me. You can report bugs using the link on the bottom of the page: https://www.sparxsystems.com/support/forms/bug_report.html
mschmitz
« Reply #2 on: January 28, 2020, 09:26:18 pm »
Hi Geert,
thx for your quick reply. Strict Connector Syntax is the trick. After turning this feature of I'm able to create meta-constraints again.
