Author Topic: EA Excel VBA Importer not loading AttributeType  (Read 4017 times)
David Ingleton
« on: January 29, 2020, 10:31:42 pm »
I am using the Bellekens Excel importer to load new columns into tables in a database model. The columns are added OK, but the datatype is empty after load. I have set the AttributeType and AttributeLength columns on the spreadsheet. Can anyone help? I have a lot of updates to make!
Re: EA Excel VBA Importer not loading AttributeType
« Reply #1 on: January 29, 2020, 10:49:40 pm »
David,
Have you tried with the newest version? 5.0?
I published this version yesterday.
https://bellekens.com/ea-excel-import-export/
I don't think the older versions properly support precision and scale, which you need for database models.
David Ingleton
« Reply #2 on: January 29, 2020, 10:59:20 pm »
Thanks Geert! There are a lot of new columns in this version, do you have any documentation yet?
« Reply #3 on: January 30, 2020, 01:25:43 am »
The documentation is on the same webpage: https://bellekens.com/ea-excel-import-export/
This new version works based on the header name, not on the position in the sheet like the previous version.
You can delete the columns you don't need.
David Ingleton
« Reply #4 on: January 30, 2020, 04:04:25 am »
I have set up the import to create 3 columns on an existing table (Action Update table, create each column). It seems to run OK but nothing is updated in EA. It did finish very quickly, as soon as I pressed OK it returned with the Finished message.
« Reply #5 on: January 30, 2020, 05:14:18 am »
If you send met the excel file I can have a look.
(maybe save it as a macro free excel, otherwise the email clients won't let it go through)
David Ingleton
« Reply #6 on: January 30, 2020, 10:33:56 pm »
Import is working OK now. Thanks for your help Geert.
