Author Topic: Is it possible to add tables to the Notes field?  (Read 4558 times)
mse
« on: January 31, 2020, 07:27:57 pm »
I would like to add tables to the notes field. However, if I paste a table in there, it gets converted to HTML table code. This however, does not show a table. Other than linked documents, is there a way to insert a table?
The reason I do not want to use linked documents is because I cannot get it to display in the diagram for example. It remains embedded with only a small red letter 'A' at the bottom right-hand corner of the activity action node.
Re: Is it possible to add tables to the Notes field?
« Reply #1 on: January 31, 2020, 10:30:55 pm »
No, not possible.
RoyC
  • Read The Help!
« Reply #3 on: February 03, 2020, 10:18:05 am »
If you want a table to display in a diagram, would a Custom Table Artifact be of use to you?
https://www.sparxsystems.com/enterprise_architect_user_guide/15.1/model_domains/custom_table_artifact.html
Best Regards, Roy
