Author Topic: Building Variants of a System and Reporting it  (Read 3696 times)
pumpidumpi
« on: February 03, 2020, 05:22:41 pm »
I've got a simple problem (I hope so ;-) ). I would like to have a basic description of a system where I can make some instances of with to choose the properties from the system for specific variants to generate afterwards an overview which variant is using which property. I made an example for a human:
https://share-your-photo.com/d32d8710a7
So now I made some instances from this (Fred and Olivia) with specific properties based on their mother:
https://share-your-photo.com/6b715eb44a
If I take a look at the traceability I can see the following information
https://share-your-photo.com/6e7437d392
Now I would like to have an complete overview of which variant is using which part and property. What are the possibilities to do that and how is the instance with its properties linked to the mother? I tried to get it via the matrix window in Enterprise Architect but I can not find the right link between them.
And a basic question, is this the right way to build variants of a system?
Would be really great if you could help me with my problem.
Thank you in advance,
Phil
Re: Building Variants of a System and Reporting it
« Reply #1 on: February 03, 2020, 05:50:32 pm »
You can use SQL to create a search, or use in a document fragment.
Link between instance and classifier is as follows
select * from t_object instance
inner join t_object classifier on instance.Classifier = classifier.Object_ID
Link between element and embedded element:
select * from t_object embedded
inner join t_object owner on embedded.ParentID = owner.Object_ID
« Last Edit: February 04, 2020, 12:50:36 am by Geert Bellekens »
pumpidumpi
« Reply #2 on: February 04, 2020, 12:14:12 am »
Thank you Geert for the quick response  :)
Do you've got some additional information to the SQL Query? This solution is very interesting.
best regards,
Phil
« Reply #3 on: February 04, 2020, 12:53:07 am »
Phil,
look for "SQL Search" in the help.
This might also come in handy: https://bellekens.com/?s=sql
