Author Topic: Repository.InvokeConstructPicker(): None or Cancel?  (Read 3326 times)
Uffe
« on: February 04, 2020, 11:15:05 pm »
Hi all,
Repository.InvokeConstructPicker() allows you to launch an EA-provided dialog to prompt the user to select one or more items from the project's model data, presented in a tree view.
If the user clicks Cancel in this dialog, the method returns 0.
But the dialog's tree view also includes a special "None" node, which allows the user to explicitly select nothing. Selecting this, and clicking OK, also returns 0.
These aren't the same case. If for instance you have a RefGUID tagged value, selecting None means "clear the tag's value" while clicking Cancel means "ignore any selections made in this dialog." The same applies when selecting a Classifier, or any other situation where EA pops this same dialog.
So is there a way to tell these two cases apart when using the API?
/Uffe
