Author Topic: Is there an easy way to show Object ID in the properties window?  (Read 7977 times)
Richard Freggi
« on: February 05, 2020, 02:27:38 pm »
I have the properties window docked on the side of the screen.  it shows lots of useful info for every element, including GUID.  My team uses Object IDs a lot instead of object names because the IDs are easy to remember 4-digit numbers instead of complicated names.  GUIDs are too long and complex for this.  We obviously list the Object ID in our SQL queries, but is there a easy way to have it displayed in the Property window instead of GUID, so we can see it real time?  Thanks!
Re: Is there an easy way to show Object ID in the properties window?
« Reply #1 on: February 05, 2020, 03:25:59 pm »
No there isn't, and be careful with those ID's, they are not stable.
There are a number of situations where such an ID could change.
The GUID is guaranteed to stay the same.
Richard Freggi
« Reply #2 on: February 05, 2020, 03:52:13 pm »
Wow thanks!  We use Object IDs quite often, especially for real-time discussions.  Do you know likely scenarios where Object ID can change?
« Reply #3 on: February 05, 2020, 03:54:00 pm »
- XMI export/import
- Version control check-out/check-in (also basically XMI export/import)
- There is also a function to re-number the ID's. (don't remember where to access that exactly)
Richard Freggi
« Reply #4 on: February 05, 2020, 04:26:31 pm »
Many thanks!!
« Reply #5 on: February 05, 2020, 05:19:07 pm »
One thing that's an easy substitute for object ids would be to add an auto-number on the alias. You can still have your 4 digit id (maybe with a prefix to denote the type) it's visible in properties, default searches and can be added to your own searches.
Modesto Vega
« Reply #6 on: February 05, 2020, 06:54:47 pm »
Is this new to version 15.1?  Was it available in previous versions v13 and v14?
« Reply #7 on: February 05, 2020, 07:25:13 pm »
This has been available since like forever  :)
Richard Freggi
« Reply #8 on: February 05, 2020, 08:03:30 pm »
Great idea!  Thanks!
