Author Topic: Can you suppress individual Tags on a diagram?  (Read 4806 times)
« on: February 05, 2020, 03:12:50 pm »
I know you can suppress individual Features (in the appropriate Feature Compartment) on a diagram via the [Ctrl+Shift+Y] Compartment Visibility dialog.
However, is it possible to do the same with the Tags Compartment?  I want to be able to suppress certain (in this case, administrative) tags from being visible in the Tags Compartment.
TIA,
Re: Can you suppress individual Tags on a diagram?
« Reply #1 on: February 05, 2020, 03:52:18 pm »
No, I don't think you can.
But you could write your own shapescript that shows only the tags you would like to show.
« Reply #2 on: February 05, 2020, 06:30:55 pm »
I didn't think so either...  But, if you don't ask, you don't get!
I'll publish a feature request when I get some bandwidth.
As you'll see from my feature request, the list of tags to show/suppress is volatile and diagram dependent.  SO TOO hard for shapescript (and it's really not its job IMV)
Takeshi K
    • Sparx Systems Japan
« Reply #3 on: February 05, 2020, 06:48:08 pm »
Hello Paolo,
The following setting might help you:
Double-click a diagram background - select Features group - enter Tag names to suppress in the 'Tag Names' textbox in the Suppress Compartment Items' panel
t-kouno
« Reply #4 on: February 05, 2020, 07:50:38 pm »
Hello Paolo,
Thanks, Takeshi, it DOES help.  It answers the first part of my proposed feature request (more later).
If I understand it correctly, it is diagram-wide.  I'd also like an element-specific version.  Can you confirm that's not possible?
Do you happen to know how I can make this applicable to the Diagram definitions in the MDG?  I quickly checked the "usual suspects" but couldn't see where EA hides the info.
PS: @qwerty can you "weave your magic"?
« Last Edit: February 06, 2020, 09:19:36 am by Paolo F Cantoni »
« Reply #5 on: February 06, 2020, 09:04:14 am »
Do you happen to know how I can make this applicable to the Diagram definitions in the MDG?  I quickly checked the "usual suspects" but couldn't see where Ea hides the info.
It appears to be in t_diagram.StyleEx,something like 'SUPTAG=a,b,c;'  You should be able to add that to styleex in the diagram profile but I've never tried it (never even knew about the feature!)
« Reply #6 on: February 06, 2020, 09:16:50 am »
It appears to be in t_diagram.StyleEx, something like 'SUPTAG=a,b,c;'  You should be able to add that to styleex in the diagram profile but I've never tried it (never even knew about the feature!)
Thanks, Neil,
Don't know how I missed it in the first look.   :-[
« Last Edit: February 06, 2020, 09:22:28 am by Paolo F Cantoni »
« Reply #7 on: February 06, 2020, 09:20:52 pm »
Hehe, another nugget. Thanks, Neil!
« Last Edit: February 11, 2020, 01:43:56 am by qwerty »
