Author Topic: Need help generating an N2 diagram or Design Structure Matrix  (Read 5215 times)
mse
« on: February 05, 2020, 07:07:22 pm »
Suppose I have a model with classes, with associations connecting each one. I would like to run a report where I generate a table with class names listed on the X and y axis and along the diagonal, the names of the classes. I would then like to output a dependency in one of the cells. Is this at all possible? Or should I just go with a traceability artifact?
See the figure on the following page which shows modules 1 through 7 on the axis, and then "x" marks showing a dependency:
https://dsmweb.org/clustering-a-dsm/
Modesto Vega
Re: Need help generating an N2 diagram or Design Structure Matrix
« Reply #1 on: February 05, 2020, 08:38:26 pm »
Have you tried matrices? Aesthetically they are clunky but they do something similar to what a Design Structure Matrix do.
AFIK there is no built-in functionality to display a matrix as a more elegant diagram, it will be good to have it. In theory, custom code or anadd-in could be written to display a matrix more elegantly. Also, document templates do not rendered them very nicely.
Having said this, INMHO it is worth a try.
mse
« Reply #2 on: February 06, 2020, 12:22:30 am »
Looks like "Matrix Specification" is the best option I have to do something like that. At least I can work inside the the matrix spec and insert <<Usage>> dependencies between modules. They are also easily exported in the document template.
It's a good start. I'll see how how it works out for us, thanks  :)
